When I try to do a make components I get this error "Could not open default template file." All the Standard.xxx files are the designated folder and named appropriately. Plus I just used this command earlier today. I did do a "rebuild all" but I'm not 100% sure the problem came directly after that.
FDS Ultimate 2013
Hi jpblower,
I found this related link, that might or might not help or at least give some ideas as to what to check:
http://forums.autodesk.com/t5/Autodesk-Inventor/make-components-stopped-working/td-p/3785563
I hope this helps.
Curtis
Hi jpblower,
I saw your post about the crash on the other thread, and it reminded me of an issue with the Make Components tool very early on. The issue was if the template had a modified sketch in it (I think). As a test, if you replace your Standard.ipt template with one that you know is clean and origina, does issue persist?
Note you can hold SHIFT + CTRL and click the New button to get a clean template to use for testing.
I hope this helps.
Curtis
