Don't worry man it is just how it is. Inventor is the most ridiculously stupid CAD Design program that exists due to its dozens of unjustified errors and warning messages. I have exactly the same problem and there is no normal reason for this to happen. Inventor is a bad joke made by a follower company. I use Inventor because I am obligated, being a student, but 90% of all the engineers are using Solid Works or other programs.
Good luck with this crap
@romeo_alex_ciontos wrote:
Don't worry man it is just how it is. Inventor is the most ridiculously stupid CAD Design program that exists due to its dozens of unjustified errors and warning messages. I have exactly the same problem and there is no normal reason for this to happen.....
Attach dataset that exhibits this "stupid" behavior.
The way you have described the general problem - I guess I am not too bright either, so I am not sure if I will be able to determine your particular problem - but I am willing to give it the old college try.
Keep in mind that it is an inexperienced student.
Give them a chance to respond in a calmer way once their frustration has subsided.
I had this same problem, and after fighting with it for a little bit I noticed an extremely simple solution. In the "Model" section of the Browser Bar there is a "Relationships" tab. Open it, and the problem relationship should have a yellow exclamation point next to it. Right-click the problem relationship and delete it (all of them if there are more than one). The operation you're trying to perform should work withuot a problem!
I apologize for resurrecting an old thread, but this was the first thing that came up when I Googled error message so I figured others having the same problem would find this thread like I did.
Sorry for resurrecting an old thread but I have a problem with this error also. Please see attached image.
I have also have attached a pack & go of the sub assembly, it is in 2015 format.
Not an explanation, but a workaround... not sure what's causing it because I don't so anything with sheet metal.
Use the edge of that flat face and the end face of the rod as your constraint, I got it to work that way.... not as elegant, but it worked.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the reply, I have mated as you suggested and it will do the job.
The error baffles me though, I am sure there must be some issue with the sheet metal component. Is there a bug reporting thread where I can bring this up?
Steve
This thread may be enough as it is monitored, but you can also use this form:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
You can also put this into the idea station, maybe it's not so much a bug as a needed enhancement.
Include your screenshots and as much info as you can.
Chris Benner
It seems as though the "Cut Across Bend" option of "Cut2" is causing the problem. If you deselect that, it will mate. Although that doesn't maintain your design intent, and is again, a work-around. This will cause the flush mate on the other rod to "error out", but you can just delete that mate, and redo it.
Thanks for the feedback.
It is quite strange, I thought initially it was the cut so I redid the cut but still used cut across bend and received the same error.
I wonder what is do different with the cut across bend option.
I don't know what else to think other than that it's a bug...
There was new functionality added to the sheet metal "Cut" in 2015, that being the "Cut Normal" option. Perhaps they messed up some adjacent code in the process? I don't pretend to understand how these issues come to be though.
Yes, I too am resurrecting an old thread. Simply because the title was what I was experiencing and I came here looking for answers. Didn't find but was encouraged to keep investigating. Now I have a solution to share.
I was attemting to put a cylinderical joint into an assembly, but kept getting the "geometry no longer exist..." error. If I put the two parts together by themselves in another assembly, no problem. So even though, the error was produced while trying to join these two parts, it had nothing to do with the two parts in question.
I finally decided to turn on "sick constraints" and found two "insert" constraints way on the other side of the assembly. They were an easy fix. After that, my cylinderical joint went in no problem.
Apparently, the slider joints and insert constraints share some deep rooted logic in the bowels of Inventor and everything gets verified before you are allowed to mix the two in an assembly.
So, you get an error message that in no way is related to your current operation......weird.
Allan
Inventor 2016
....still learning
