When i attempt to open an IGS file i get "an unnnamed files contains an incorrect path"
Any idas would be helpful? i dont really want to pay $200 to Autodesk to assist.
thanks,
1. How do you know it is not corrupted if you can't open it?
2. How do you know you were successful creating if opening failed?
Did you follow the Autodesk document for Clean Uninstall when you did the uninstall/reinstall?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187758&linkID=9242018
Did you turn off UAC and anti-virus during reinstall?
Do you have Options set to not create html report?
Attach an IGES that YOU created here.
I am having the guy who uses Inventor to send me the file. Will you test it on your end? please check my answers in red.
I dont, we only have one user using inventor, so i will send it to you and see if you can open.
That i am not sure, we were able to create it without any errors.
Yes
Where is this found?
In Options when opening the file.
I don't recall if it was in 2010.
Select file to import (but don't open yet).
Click Options
You might have to search around here for a Registry edit for 2010 if it was not available in the dialog box.
There was a problem caused by this report generation on some machines.
JD, was it a registry edit or environment variable you are reffering to?
I've been getting this same error off and on for a while working with STEP files, and I finally figured out the problem. Inventor can't open files when the combined length of the path and filename is greater than 128 characters (excluding the extension). This behavior appears to be the same on local or network drives. It will happily save STEP files with a longer path+filename length, it just won't open them. I'm using Inventor 2012 SP2 64-bit. This issue doesn't appear to occur with native Inventor files, or with Inventor Fusion at all. Autodesk, can you please fix this bug in Inventor?
