We use to color components in idw drawings very often. And when we have drawings of large assemblies we lose a lot of time for that. Usually we select the parts from views (having "Part Priority" in Filter Selection), right click and from the properties we change the color.
I was thinking if there could be faster ways to do it. For example to create a command (which later should accesed via a button on keyboard) that will call the colors window in the components properties, having the part already selected.
Probably I need a .vba code or an ilogic rule to create this command. Can someone help me in this regard?
Or does someone have better ideas for coloring the parts?
Alexandru
Here is a link to a thread that has a rule started that works on small assemblies.
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-component-edge-color-in-IDW-view/td-p/3325285
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I'm thinking Idea Station... to have an option to show parts in idws outlined in the model color? Hmmm.....
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
