Hi Blane
Glad you like it 8^)
It has been a while since I dug through that code, but when you pick a hole I am pretty
sure it has to be on a Face. About the only think I could suggest is to select the top of
the countersunk bolt and the top of the hole, and use whatever offset you need to get it
right. I build my iPart screws to match my standard countersink, so I use that method
without any offset.
Charles is pushing to get me to look at some cases where KWiKSert has problems with
surfaces or something so If I find time to look into that I will see if there is any
possibility of making do what you want. At this point I am guessing it isn't going to be
possible though.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"BTBeilke" wrote in message
news:469AB8F943C0B2D19E43FC017CEF9CF6@in.WebX.maYIadrTaRb...
> I have become heavily dependant upon your KWiKsert program to place
> fasteners (iParts, not library parts) in my assemblies. However, in my
> current assembly, I have a bunch of liners with countersunk holes into which
> I am trying to KWiKsert Flat Head Socket Cap Screws, without much success.
> I need to constrain the base of the flat head (where the countersunk angled
> face of the head meets the body of the bolt) to the base of the countersunk
> portion of the hole in the liner. When I pick those features, I get the
> attached error message. KWiKsert will go ahead and place the bolt, but it
> either wont be in the proper orientation (going through the hole the wrong
> direction) or it aligns with a different surface so that it is not setting
> all of the way in the hole. Am I doing something wrong?
> Thanks for your help. Like I said, I use this tool a lot.
> Blane
