Inventor Forum
Question about extending a 3DSketch
6 REPLIES 6
karthur1
390 Views, 6 Replies
I would like to be able to offset a 3D Sketch in a direction normal to a plane.  In the attached image, I have drawn in an orange color the direction I would like the 3DSketch to offset.The white line is where the new sketch would be.
The yellow surface is the 3dsketch extend to a plane
There might be some tools in Inventor that will do what I am trying, but I have not found it yet.  I have tried extend surface, but that will not take it the direction I want.
6 REPLIES 6
WHolzwarth
in reply to: karthur1
Hi Kirk,
perhaps like this?
Walter
Walter Holzwarth
karthur1
in reply to: WHolzwarth
Walt,
My 3dsketch is projected from an imported parts edge.  It is not generated from an intersection of a surface like you have... so I cant just offset the surface like you did.
Hope that makes sense.
cwhetten
Maybe sweep the 3D curve in that direction as a surface?
Cameron Whetten
Inventor 2012
WHolzwarth
Can you show your IPT, Kirk?
Walter Holzwarth
glenn-chun
Hi Kirk,
It looks like you want to extrude a 3D profile by vector.  The vector would imply both direction and length of the extrusion.  Autodesk ShapeManager provides this functionality, and it's available in AutoCAD, but not in Inventor.  If you would like this functionality in Inventor, please post your request to the Inventor IdeaStation.
There is a workaround in Inventor -- Parallel sweep (aka rigid sweep).
  • The vector for extrusion above is the linear profile in parallel sweep below.
  • The 3D profile for extrusion above is the 3D path in parallel sweep below.
Hope this helps,
Glenn
Autodesk ShapeManager Development
Glenn Chun
Sr. Principal Engineer
rdyson
in reply to: glenn-chun
Or maybe something like this, using Walters part
PDSU 2016
