Inventor General Discussion
Valued Contributor
hajimeml
Message 1 of 18 (958 Views)
Quadro or Gaming card for Inventor?
958 Views, 17 Replies
08-08-2012 05:58 PM
Some people suggested me to get a gaming card such as the GTX590 instead of the Quadro 4000 or 5000. The reason is that "It's my understanding that since Inventor moved away from OpenGL to DirectX, workstation cards aren't really a necessity like they used to be."
Is this true? Given a choice, which of the above cards would you chooce?
Inv_kaos
Message 2 of 18 (954 Views)
Re: Quadro or Gaming card for Inventor?
08-08-2012 06:39 PM in reply to: hajimeml
Correct, we run professional cards but there is no need these days. Go for value for money and get a top end gaming card such as the GTX590.
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Valued Contributor
hajimeml
Message 3 of 18 (951 Views)
08-08-2012 07:13 PM in reply to: Inv_kaos
Which is the highest performance card? Silency is an important factor.
blair
Message 4 of 18 (939 Views)
08-08-2012 10:07 PM in reply to: hajimeml
We used to run Quadro cards, but have now switched to fast "gaming" cards. Either the Nvidia or AMD cards work fine. We have gone with the EVGA cards, if you register their product within the set period, their warranties are quite long. If someone is willing to stand behind their product for a long period of time, you would guess their build quality is good along with used components.
Google search for graphic card ratings, there are a number of sites that test the card.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
Valued Mentor
mpatchus
Message 5 of 18 (909 Views)
08-09-2012 03:48 AM in reply to: hajimeml
Make sure that your workstations support the gaming cards.  We have found that our Lenovo workstations won't utilize the gaming cards.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
mcgyvr
Message 6 of 18 (893 Views)
08-09-2012 05:44 AM in reply to: mpatchus
huh? why.. never heard/seen that before.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Mentor
mpatchus
Message 7 of 18 (879 Views)
08-09-2012 06:30 AM in reply to: mcgyvr
We tried putting a GeForce GTX580 into one of our Lenovo D20 Workstations and the bios had a fit.
Contacted Lenovo and were told that the D20s were not compatible with the gaming cards, only with the Nvidia Quadro  cards.
We tried the same test on another D20 with an AMD Radeon 6870 card and had the same results.
First I've heard of such a thing either.  ???
Mike Patchus
*Pro
sbixler
Message 8 of 18 (878 Views)
08-09-2012 06:37 AM in reply to: mcgyvr
Not sure what mpatchus is referring to, but I've got a GTX 560Ti in an HP Z600, and there's not sufficient power taps available-- the Z600 power supply has only one 6-pin PCI power connector, and only one available Molex 12 V peripheral power connector.  The 560Ti needs two 6-pin power connectors (one of which can be supplied by two Molex connectors).
The 560Ti works, but it doesn't have all the power available that it needs, on a workstation with a 600W power supply!
sam_m
Message 9 of 18 (873 Views)
08-09-2012 06:50 AM in reply to: mpatchus
what psu has it got tho?  Only reason I can think for any pc to be "incompatible" with a gpu (assuming it's the correct slot on the motherboard).
googling "Lenovo D20 geforce" gives the link below - shows that gaming cards do work on the system, so can only imagine the problem was the psu-demands of the higher-end gaming cards.
http://forums.lenovo.com/t5/ThinkStation/ThinkStation-D20-and-graphics-card-with-power-cables/td-p/6...
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Bill.Schmid
Message 10 of 18 (862 Views)
08-09-2012 07:28 AM in reply to: Inv_kaos
I was beginning to wonder about gaming cards.  Good to know.
First question would be, do they still work OK with AutoCAD?
Second question, is the new hot CAD system going to be a good gaming computer instead of a "workstation?"
(NOTE:  If trains stop at train stations, what happens at a workstation?)
