Does anyone knows any QR code creator to use in IDW.
Explaining: having the internet adress and putting it in the creator it creates the image code somewhere in the IDW..
Thanks in advance
FG
Solved by Curtis_Waguespack. Go to Solution.
If a bar code is sufficient, you could install a barcode font and use that in a text on the drawing: http://www.barcodesinc.com/free-barcode-font/
I guess qr code requires an addin (or manually inserting a picture of the code)
generate the QR code.. save as image..insert into IDW.
what I want is to have something to put the link in the idw and somehow it creates the QR code by generating the image not by inserting an outside pic by an external generator... any ideias
To place a QR-code directly in your idw you need to do some programming. Have a look at zxingnet, thats a library to create qr images. What's the purpose of the qr-code in your idw? I tested a bit with drawing an qr-code in a sketched symbol, but with the filled rectangles it's really memory consuming. To heavy for my system.
Rob.
Hi fgarcia90,
If you use Inventor DWG rather than IDW, you might be able to open the file in AutoCAD and generate the QR-code using this tool:
http://www.youtube.com/watch?v=5v4cSTqhe_k
I've not attempted this, but thought I'd pass along the link.
Update:
I just created an IdeaStation request for this, you can vote for it at this link:
I hope this helps.
Curtis
Curtis, my Kudos is done!
Vdveek, the are plenty of softwares to create QR outside of inventor.
In our company we create our technical catalog to every single one of our products, and it would be great to have something to put links in the IDWs directly saving files and time to redirect our costumers to our web page. Comercial things you know
You said you have something but is too heavy... can you share a file so I can try it?
Thanks for contributions
FG
FG, i will send you an example this evening.
The test of placing an QR-code in a sketched symbol is done the following way.
Create online an QR-code on a website where you can save the image to *.svg (vector drawing). Save the .svg and open it in excel. A *.svg is based on the xml-structure so Excel wil convert the svg into colomns. (Please note, different websites create different svg files i find out). Now with iLogic i read out this excel-file and draw for each row a rectangle based on the X,Y coordinates and the width and height values. The problem is the filling of the rectangles, that's way to slow.
Example of an svg file in excel.
width height version ns1:desc id fill x y width2 height3 fill4 99 99 1.1 Zint Generated Symbol barcode #000000 0 0 99 99 #FFFFFF 99 99 1.1 Zint Generated Symbol barcode #000000 12 12 21 3 99 99 1.1 Zint Generated Symbol barcode #000000 39 12 9 3 99 99 1.1 Zint Generated Symbol barcode #000000 54 12 3 3 99 99 1.1 Zint Generated Symbol barcode #000000 60 12 3 3 99 99 1.1 Zint Generated Symbol barcode #000000 66 12 21 3
But a better way will be to write your own vb-code with the Zxing-librarie, so you can use it without internet based qr-websites. This need definitly more testing, but i found out that it;s posible with iLogic. Now i need the time to write a vb.net add-in.
Rob.
Anybody have references for the structure of QR codes? Once the creation process is better understood the automation of that process would be easier to implement.
Hi everyone,
michael.navara was kind enough to share this link to another tool on the Exchange site that can be used to create QR codes:
I hope this helps.
Curtis
I've been doing some digging on the format (well, as much as not spending ~ $250 on the ISO standard will allow). The procedure in creating a QR code is just a *little* more complicated than switching to a bar code font:
Structure of QR Code? I found this passage called QR Code introduction has the structure of QR Code. I can help you understand. QR Code is now really getting more and more popular. I am also creating QR Code in my business.
fgarcia90 I created an Addin to place a QR-code image on a drawing. It's posible to copy iProperties from the drawing or from the Base-model to a sketch symbol containing the QR bitmap. Sadly the qr-code is not dynamic, when you want to make changes to the qr-code you need to create a new one. But it's posible to save the text to a custom iProperty for later use.
Hope it works for you, otherwise let me know.
Tested on Inventor 2012 x64 an 2013 x64.
Guys, just solved the question migrating to Inventor 2014 and using the app X-Tools LT...
as Curtis pointed and seem's a nice solution.
Just one thing I think it couldf be very usefull, ist that the text/link could be place in the prompted entry.... any ideias...
Thanks all for your suggestions..
"Anybody have references for the structure of QR codes? Once the creation process is better understood the automation of that process would be easier to implement."
You can take a look at this QR Code introduction.
VB.net is a slightly different language than VBA (The program-enviroment in Inventor). And it's not completly compatible. Is VBA still integrated within Inventor 2014? I heard they will stop vba.
I can change my Addin so it can read the prompted value. But why don't use the iProperties?
Rob.
