Inventor Forum
Putting a hole into a curved surface
30 REPLIES 30
Message 1 of 31
wiggi
903 Views, 30 Replies
Hi
I am new to inventor and I am trying to create one of my first components having had no lessons. I have managed to create the component for a camera stableiser for my A-Level project. I need to put a hole through the flat section on the curve in the middle about 20mm from the end on the bottom that goes all the way through the material for a bolt. I have watched lots of videos and webpages and have not worked out what i need to do. I have attached the file any help would be greatly appreciated.
30 REPLIES 30
Message 21 of 31
JDMather
in reply to: wiggi
I do not see any Horizontal constraints.
I do not see any Vertical constraints.
Message 22 of 31
wiggi
in reply to: JDMather
I have added a horizontal constraint but i cannot add the vertical as  a over constrain message pops up.
Message 23 of 31
JDMather
in reply to: wiggi
Edit the sketch.
Drag one of the vertical lines.
Notice that there is not a coincident constraint to the origin centerpoint.
Message 24 of 31
wiggi
Okay thank you it is now telling me it is fully constrained somehow.
Message 25 of 31
wiggi
in reply to: wiggi
Okay I think i may have sorted the constaints i have 2 weeks to get this sorted. I have attached the component could someone please give me some more help. 🙂
Message 26 of 31
JDMather
in reply to: wiggi
How is this part made and what is the material?
Is this a bent sheet metal part?
Message 27 of 31
wiggi
I have already manufactured this part through the bending of plywood
Message 28 of 31
wiggi
in reply to: wiggi
I am making the component to add to my portfolio to illustrate what i have already made and to explain to someone how they could manufacture it. If it helps show you what i am trying to achive i have linked the assembly file at its current stage as well as the frame section which i am trying to put the hole in. The hole will have a bolt put through for masses to be placed to counter balance the rig. (its a camera steadi)
Message 29 of 31
wiggi
in reply to: wiggi
Message 30 of 31
JDMather
in reply to: wiggi
I do not see a bend here.  Is this two parts or one part?
Message 31 of 31
wiggi
this is one part but as you may have guessed i am not that good with cad and this is the best that i could do
