Hi
I am new to inventor and I am trying to create one of my first components having had no lessons. I have managed to create the component for a camera stableiser for my A-Level project. I need to put a hole through the flat section on the curve in the middle about 20mm from the end on the bottom that goes all the way through the material for a bolt. I have watched lots of videos and webpages and have not worked out what i need to do. I have attached the file any help would be greatly appreciated.
I do not see any Horizontal constraints.
I do not see any Vertical constraints.
I have added a horizontal constraint but i cannot add the vertical as a over constrain message pops up.
Edit the sketch.
Drag one of the vertical lines.
Notice that there is not a coincident constraint to the origin centerpoint.
Okay I think i may have sorted the constaints i have 2 weeks to get this sorted. I have attached the component could someone please give me some more help. 🙂
How is this part made and what is the material?
Is this a bent sheet metal part?
I am making the component to add to my portfolio to illustrate what i have already made and to explain to someone how they could manufacture it. If it helps show you what i am trying to achive i have linked the assembly file at its current stage as well as the frame section which i am trying to put the hole in. The hole will have a bolt put through for masses to be placed to counter balance the rig. (its a camera steadi)
I do not see a bend here. Is this two parts or one part?
