Hi
I am new to inventor and I am trying to create one of my first components having had no lessons. I have managed to create the component for a camera stableiser for my A-Level project. I need to put a hole through the flat section on the curve in the middle about 20mm from the end on the bottom that goes all the way through the material for a bolt. I have watched lots of videos and webpages and have not worked out what i need to do. I have attached the file any help would be greatly appreciated.
like this?
First off, you're doing WAY too much work here.
While I understand that you're trying to do this entirely self-taught - and I really do understand this, as that's how I got started with Inventor as well - there's no crime in getting some basic tutorials. Look for posts on here by JD Mather. Go through the tutorials in his sig line. They will REALLY help you out a lot with your basic modeling techniques. I very much recommend doing this, and then going step by step through every single one of them. (Granted, they're from an older version of Inventor, so things will look a little different, but the tools will still work pretty much the same way.)
Second, you've got tons of extra sketches that are not obviously being used for anything. Now I'm the first one to admit that I'm completely OCD when it comes to having clean geometry and no extra stuff laying around, but there is definitely a benefit - performance-wise - to minimizing the amount of extra sketches.
As far as where you want the actual hole ... can you put a scribble of some sort on the location where you want it? I'm not quite positive where you're trying to make it ...
Rusty
wiggi,
How motivated are you to learn to do this correctly?
(I ask, because many students come here asking for help and the disappear in 2 or 3 days.)
The first step in starting any part is to select a logical location for the origin datum.
Second step is to look for features of symmetry in the design.
Start a new part file.
Sketch the arc with the centerpoint at the Origin Center Point.
Notice the angled lines have an Symmetry constraint to the horizontal line.
Notice that in the lower right corner of the screen that Inventor reports Fully Constrained.
Create this sketch as shown and attach your new file here.
Where did you go?
Sorry I had to go last night i am going to have a go this evening I will just create the 2d sketch as illustratured
Your method is different than the image I attached - but it will work if you,
add Vertical constraints to the vertical lines.
And add a coincident constraint between the left vertical line midpoint and the origin center point.
Once you get better at sketching Inventor will automatically add all of these constraints.
Add the constraints and post the file back here again.
When your sketch is fully constrained - it will change color and report in the lower right corner of the screen Fully Constrained.
Thanks again mine matches the picture now although it does not say fully constraint im not sure if this is because i am using a different version (inventor pro 2014)
Did you attach the correct file (this doesn't look any different than the last attachment)?
The constraining has nothing to do with the version - this has not changed in the 12-13 years that I have been using Inventor.
Sorry it may have been wrong file i will re-attach. There are no visual differences but if you open sketch it shows constraints
