So, to clarify, just turning the visibility of all the other layers OFF made
the offending layer purgable?
If that's true, can you send me that file so I can have QA look at it?
Andrew Faix
Product Design Lead
Autodesk Inventor
wrote in message news:5935982@discussion.autodesk.com...
Thanks, Andrew.
What finally worked was turning the visibility of all the other styles off.
The problem style was then exposed for purging from the Format pull down
menu.
Kinda weird because no entities were linked to the problem style, so I
should have seen it when doing the purge.
Steve
