Inventor General Discussion
Valued Contributor
lester
Message 1 of 5 (357 Views)
Purchased parts in parts list ??
357 Views, 4 Replies
04-25-2012 11:18 AM
Is there a way to have a column in the parts list that shows the purchased parts?
I want the info from the BOM called BOM Structure to show in the parts list.
mcgyvr
Message 2 of 5 (345 Views)
Re: Purchased parts in parts list ??
04-25-2012 12:18 PM in reply to: lester
Pretty sure the answer is no (as it should be).. BUT you can do a parts list filter and have it only show purchased parts.
Do you not have an ERP system? You should. Purchasing based off a drawing is just silly.
You can also just export the BOM and get that information.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Product Support
pierre.masson
Message 3 of 5 (306 Views)
04-30-2012 02:48 AM in reply to: mcgyvr
Mcgyvr is right and using a part list filter is a good solution.
We can also scan the assembly and set a custom Iproperty that writes the BOM Structure from structured BOM.
You can copy this piece of code in your ILogic, and use Itrigger tu run this rule each time you save for example.
This rule will scan your assembly and subassemblies, use the structured BOM Value and implement this value in a custom Iproperty in the file. You can display this custom Iprop in your parts list afterwards.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
Product Support
pierre.masson
Message 4 of 5 (305 Views)
04-30-2012 02:49 AM in reply to: pierre.masson
The code
Option Explicit
Sub Main Correct_G_L_parameter()
        ' Set reference to active document.
        ' This assumes the active document is an assembly
        Dim odoc As Inventor.AssemblyDocument
        odoc = ThisApplication.ActiveDocument
        ' Get assembly component definition
        Dim oCompDef As Inventor.ComponentDefinition
        oCompDef = odoc.ComponentDefinition
        Dim sMsg As String
        Dim iLeafNodes As Long
        Dim iSubAssemblies As Long
        ' Get all occurrences from component definition for Assembly document
        Dim oCompOcc As ComponentOccurrence
        For Each oCompOcc In oCompDef.Occurrences
            ' Check if it's child occurrence (leaf node)
            If oCompOcc.SubOccurrences.Count = 0 Then
                iLeafNodes = iLeafNodes + 1
                Call Assign_BOM(oCompOcc)
            Else
                iSubAssemblies = iSubAssemblies + 1
                Call processAllSubOcc(oCompOcc, _
                                    sMsg, _
                                    iLeafNodes, _
                                    iSubAssemblies) ' subassembly
            End If
        Next
        odoc.Update
        'Save the assembly
        'odoc.Save
    End Sub
    ' This function is called for processing sub assembly.  It is called recursively
    ' to iterate through the entire assembly tree.
    Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, _
                                 ByRef sMsg As String, _
                                 ByRef iLeafNodes As Long, _
                                 ByRef iSubAssemblies As Long)
        Dim oSubCompOcc As ComponentOccurrence
        For Each oSubCompOcc In oCompOcc.SubOccurrences
            If oSubCompOcc.SubOccurrences.Count = 0 Then
                Call Assign_BOM(oSubCompOcc)
            Else
                sMsg = sMsg + oSubCompOcc.Name + vbCr
                Call processAllSubOcc(oSubCompOcc, _
                                      sMsg, _
                                      iLeafNodes, _
                                      iSubAssemblies)
            End If
        Next
    End Sub
    Private Sub Assign_BOM(ByRef oCompOcc As ComponentOccurrence)
        Dim Bomstructure As String
   Dim odoc As Object
      Dim oPropSets As PropertySets
      Dim opropset As PropertySet
     Dim oUserPropertySet As PropertySet
Dim i As Integer
        odoc = oCompOcc.Definition
oPropSets = odoc.Document.PropertySets
        Select Case odoc.Document.ComponentDefinition.BOMStructure
  Case 51969
      Bomstructure = "Default"
  Case 51970
      Bomstructure = "Normal"
  Case 51971
      Bomstructure = "Phantom"
  Case 51972
      Bomstructure ="Reference"
  Case 51973
      Bomstructure ="Purchased"
  Case 51974
      Bomstructure ="Inseparable"
  Case 51975
      Bomstructure = "Varies"
  Case Else
      Bomstructure = "Unknown"
  End Select
MsgBox (Bomstructure)
For Each opropset In oPropSets
    If opropset.Name = "Inventor User Defined Properties" Then oUserPropertySet = opropset
Next opropset
' If Property does not exist then add the new Property
On Error Resume Next
        Call oUserPropertySet.Add(Bomstructure, "BOM")
' Try to set the Property value if it already exists
 For i = 1 To oUserPropertySet.Count
   If oUserPropertySet.Item(i).Name = "BOM" Then oUserPropertySet.Item(i).Value = Bomstructure
 Next i
    End Sub
Valued Contributor
lester
Message 5 of 5 (295 Views)
04-30-2012 05:29 AM in reply to: lester
Thank you for JD and your reply. This will help me.
