Inventor Forum
Punches
2 REPLIES 2
ASchlaack
169 Views, 2 Replies
Punches
I'm trying to make a punch of an "&". But I keep getting this error when trying to Extract Feature.
Does anyone know what's causing this?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
2 REPLIES 2
mcgyvr
in reply to: ASchlaack
I'd guess the projected loop of cut 4..
You don't need to project the edges and in fact don't want them in a punch..
Just a single centerpoint and your cut
CCarreiras
HI!
You cannot use loop or projected geometry in punch.
Just remove that from the sketch and it will work ok.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
