Inventor Forum
Punch Tool creation help
3 REPLIES 3
AlexFielder
1453 Views, 3 Replies
Hi all,
A colleague & I have been trying and failing all day to create a punch tool from scratch.
I did however manage to modify the geometry of the Dimple & Hole example here:
http://www.cbliss.com/inventor/iFeatures/index.htm
Can anyone point me in the direction of step-by-step instructions for how to a) build the iFeature correctly and b) how to then extract it so that the orientation is not FUBAR when you insert it using the punch tool.
Attached are the dimensions I need.
This shape when revolved about the centreline should produce a 'dimple' effect in the sheet metal part.
Alex.
Tags (2)
3 REPLIES 3
mcgyvr
in reply to: AlexFielder
http://www.widom-assoc.com/html/ifeatures_-_punches.html
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11767919
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11768082
http://au.autodesk.com/?nd=tech_talk_detail&article_id=10&jid=9835
AlexFielder
in reply to: mcgyvr
Thanks for the links mcgyvr; the first one is exactly what we needed. Smiley Happy
Speaking of which, do you have any idea why if I use as my centre point the point circled in the attached image; that the resultant iFeature doesn't align as you would expect?
Tags (2)
JDMather
Can you attach the punch file and the part you pictured here?
Make sure when creating the Punch tool that you delect any autoprojected origin centerpoints from the sketches.
