Inventor Forum
Punch features sketch in derived part
10 REPLIES 10
Message 1 of 11
carstn
819 Views, 10 Replies
Hi
I'm deriving(mirroring) a sheet metal part with 2 different punch features, which both contain a sketched symbol for the CNC-punching machine. All is ok in the base component. Then i derive it into a new part - make the new flat pattern - still ok. Now i choose "Edit flat pattern definition" and checks "2d sketch representation" and then the feature disappears, as intended, but its not showing the sketched symbol. Where did it go?
This funktion works fine in the base component...but not on the derived par. It must be compatible since the feature disappears - or what?
Carstn
Inv. 2008
XP Pro sp2
10 REPLIES 10
Message 2 of 11
Yijiang.Cai
in reply to: carstn
It is really reproducible on R2008. But it does work fine on R2009 and R2010.
River
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 3 of 11
carstn
in reply to: carstn
Here's an example made in Inventor 2010 - same result, on my machine anyway...
/Carstn
Attached: derived and base component
Inventor 2010
Windows 7 /64bit
Message 4 of 11
skyngu
in reply to: carstn
hi,
I have same issue in inventor 2013. when i turn on punch representation, It doesnt show punch sketch (louver in my sample part) on derived part. it works fine in base part.
is it just my problem or known issue?
thanks
Autodesk Inventor Professional 2019
Tags (2)
Message 5 of 11
Yijiang.Cai
in reply to: skyngu
Please see the attached model, and it works fine on R2012 and R2013.
River Cai
Autodesk, Inc.
Message 6 of 11
skyngu
in reply to: Yijiang.Cai
hi,
thanks for reply.
I open your sample parts. I find out one thing. see attachment.
why the sketch not on the part? it is flowing around. does that trick made it work?
So it is how we make punch tool instead of sheet metal problem.
thanks again.
Message 7 of 11
skyngu
one more testing, the sketch is not showing up when I switch mirror plate from xy to yz.
test3.zip is the punch i am testing. the sketch is not showing up.
thanks
Message 8 of 11
Yijiang.Cai
in reply to: carstn
Yes, it will be reproducible when changing the mirror plane, and the position of punch representation looks incorrect. And this issue has been tracked in our system as 1471193.
River Cai
Autodesk, Inc.
Message 9 of 11
skyngu
thanks for the reply.
is there any way we can look for the track number at system? such as web site?
Message 10 of 11
JelteDeJong
Any progress on this topic? im working with inventor 2018 and still have this issue.
Jelte de Jong
Blog: hjalte.nl - github.com
Message 11 of 11
johnsonshiue
in reply to: JelteDeJong
Hi! In terms of the exact workflow, I don't believe there is a change in behavior as of Inventor 2021. But, I suspect this particular request may be fulfilled by our internal project called Model States. Please sign up Inventor Feedback Community (https://autode.sk/InventorBeta). There you can try the latest internal builds with in-development functionalities in an install-free environment and give feedback to the project teams.
The workflows we are working on eliminating the need to derive a part in order to have a different shape. And, the punch center in the flat pattern can be retrieved properly (in the drawing too).
Many thanks!
Software Test Engineer
