Inventor Forum
Pulling iProperties from drawing sheets
7 REPLIES 7
Message 1 of 8
drguitarum2005
871 Views, 7 Replies
Is there a way, in my drawing template, to set one field as "Part Number iProperty from parent assembly on sheet 1 base view"? I want every single sheet in my .idw to reference the same "Part Number" iProperty from the assembly in the base view of sheet 1. Thanks!
7 REPLIES 7
Message 2 of 8
JachinMK
in reply to: drguitarum2005
Hi there,
try this out. I use it to show the partnumber on another sheet that includes the parts list.
it actually writes the part number of the first placed model into the custom properties. (so you can use it in a titleblock)
you need to name a text parameter Part_nr_sheet1
' exit rule if no part or assembly is in the drawing yet
If (ThisDrawing.ModelDocument Is Nothing) Then Return
'get the filename of the doc the drawing points to
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
Part_nr_sheet1 = iProperties.Value(modelName, "Project", "Part number")
'fires the part nr as shown in the first sheet so it can be used in the partslist sheet titleblock
'without having a drawing view on that sheet
Dim propertyName1 As String = "Part nr list"
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
oProp = oCustomPropertySet.Item(propertyName1)
Catch
oCustomPropertySet.Add("", propertyName1)
End Try
iProperties.Value("Custom", "Part nr list") = Part_nr_sheet1
iLogicVb.UpdateWhenDone = True
hope this helps you out!
cheers,
Jachin
Message 3 of 8
devonjohnson
in reply to: JachinMK
Hi there,
Thanks so much for this rule, I've added it to my drawing template and it works great for iam and ipt files but it brings up an error for presentation files.
"Object reference not set to an instance of an object."
Can the rule be tweaked to suit all files?   I'm trying to amend it myself but not luck so far...
Thanks for your help.
Devon Johnson
Inventor 2020
Message 4 of 8
rki
in reply to: devonjohnson
Hi Devon,
Did you ever get this working? I have the exact same problem now:-(
Br.
Rasmus
Message 5 of 8
devonjohnson
in reply to: rki
Yes I did get it to work, here is the code I used. Hope it helps!
Dim presDoc As Document
presDoc = ThisDrawing.ModelDocument
Part_nr_sheet1 = presDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Try
Catch
End Try
Devon Johnson
Inventor 2020
Message 6 of 8
rki
Hi Devon,
Thanks, this works. Just not the way I intended.
I need the I ipropperties from the .iam not the .ipn.
Essentially I just need the error message to dissapear. (see attachment.) then I will use the good old copy model propperties for the .ipn since this takes the ipropperties directly from the .iam ie. it skips the .ipn ipropperties.
Any ideas?
Br.
Rasmus
Message 7 of 8
rki
in reply to: rki
Hi again Devon,
I solved the problem, and smarter than I could have ever hoped.
Instead of moving data from one file to the other I made my .idw templete grab all the data from the source ie. .ipt or .iam (like it also grabs the geometry)
This removes the need of ever copying propperties from one file to another.
Really only posting this because I am so releaved and had to share it 🙂
Br.
Rasmus
Message 8 of 8
dpvandermaat
 How do you then link this text parameter Part_nr_sheet1 to an iProperty that you can then place on a drawing sheet/title block?
