Inventor General Discussion
Member
rodrigotito
Message 1 of 2 (62 Views)
Publish Frame Content Center
62 Views, 1 Replies
04-17-2012 07:40 AM
I am trying to publish a profile in my library and I can not.
The difference I noticed is that now I'm working on sheet metal environment and sometimes it was in part.
In the process get an error stating that there is a point in the design of extrusion ... Only if I can publish my piece is an extrusion?
Attached is the part that I can not publish
Thanks!
Inventor 2012
Curtis_Waguespack
Message 2 of 2 (59 Views)
Re: Publish Frame Content Center
04-17-2012 07:52 AM in reply to: rodrigotito
Hi rodrigotito,
Rob Cohee has a video on the subject of publishing sheet metal components to use in Frame Generator:
http://youtu.be/1Ff9yIVNAa4
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
