Inventor Forum
Properties fail on imorted model using standard material
4 REPLIES 4
gcross
298 Views, 4 Replies
I cannot get any properties to show anything but  "N/A" except for density on a imported STEP CAD model. It was exported to STEP from SW (ver. ?) I think & I saved it as an Inventor .ipt (part is attached).
I assigned Polycarbonate, Clear material, a standard material in Inventor & Autodesk Material Libraries.
Can someone take a look to see what can be done to enable properties to show.
Gary
IV 2014 latest SP
Dell Precision Xeon W3690 3.47Ghz/12GB/4x WD Raptros (RAID 5)
Quadro 4000
Dual Dell 24" Monitors
4 REPLIES 4
JDMather
in reply to: gcross
Try this one.
Cadmanto
in reply to: gcross
Gary,
Take a look at the attached file.
I have been doing some experimenting and what I found was if I brought in Solidworks files into Inventor they all came in with the "N/A" in the properties.  But, when I took your file, called it up, then exported it out as a step file then reinserted it, it came in with all of the properties calculated and filled in.  Don't ask me to explain it, but it worked!!!  Smiley Happy
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Cadmanto
in reply to: gcross
By the way, I forgot to mention that in your file if you look at the report file in the browser, it tells you that the Solidworks version is 2013.
Best Regards,
Scott McFadden
gcross
in reply to: JDMather
JD,
Did you export as STEP & re-import into inventor like Cadmanto?
Gary
