Does anyone else notice if you open say, a drawing that is in Vault, it asks if you want to check it out, and if you say no (like if you just need to print it), it opens it then asks you again if you want to check it out? Did it not get the hint the first time? Anyone else's do this as well?
Yes, I have gotten that before. If you do these steps all the time and find this extremely annoying, as long as you are an admin to the vaul there is a location within the options to override the default answer and not have this message come up.
My suggestion would be to either print the drawing from within the vault client or do the same to the dwf file.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
