Is there a way to setup prompted entry data in a say a title block to automatically "copy" over to new sheets upon creation, instead of having to refill them out each and every time you make a new sheet?
there are various ways to get them filled ...but you might be better of doing it with custom iproperties ....
then you can populate them via Vault, Design Assistant and even Windows Explorer. I had a set of over 100 idw's and I populated them all via RMB and windows explorer.
here is an example of howe we do it:
You can make it a prompted entry if need this way too
I dont mind the prompted entry way, I actually like it better than filling out data with I Props. I guess my wish was that when I fill out my Title Block on Sheet 1 with data that will not change like Job Number, Customer Name, Ect...I would be nice if you could just copy Sheet 1 and create Sheet 2 from it within the same .idw, and have that info already there without having to fill it out again with prompts. Not sure if that makes sense or not?
Are you using Prompted Entry or I Props?
Pic 1: Maybe I am setting it up wrong somehow, here is what I have as formatted text.
Pic 2: Shows that it allows to copy the Sheet, but not paste?
Pic 3: Is how I create additional sheets within the .idw, but I get prompted to fill out my title block each time, even though I already did it for sheet 1
How are you getting the Data to transfer over to each new sheet?
I was a 'prompted entry' guy too! Until I was shown how to make forms and use iProps. The reason why I stopped using Prompted Entry was due to the very same problem you are facing. I constantly had to re-enter information when creating a new sheet. Now I only use PE for things that change from sheet to sheet (Drawing Title, Drawing Number, etc...) Now when I create a new drawing from scratch, a form will pop open and I enter any info that will not change from sheet to sheet (Job Title, Number, Client Name, etc...). This is especially nice for sheets that have information shown in multiple locations. For example, most of our Certification drawings we create call out information on multiple places in our drawings, by creating an iProperty and placing that text wherever I need it, I can rest assure knowing that when I enter information into my form (say Tool ID Number), I know that each spot that has that iProperty will be filled in correctly. Thereby, eliminating the possibility of me forgetting to enter it in or if something changes, I can update all the changes with one simple correction.
It is very simple! Heck if I can do it, anyone can! I was shown through help on these forums.
Here is the link to get your form to open up when startings a new drawing...
http://forums.autodesk.com/t5/Inventor-General/Opening-a-Form-when-New-Drawing-Created/m-p/3923571/h...
Create iProperties First:
Create Form:
@michaeldavis7418 wrote:
I like the Iprop vs Ilogic ...because I can populate it from the Vault, Design Assistant and windows Explorer.
You can still use those methods to populate the iProps when you have an iLogic form, the form is just an additional pretty, user friendly, customizable method for property entry. You're still using iProps either way.
hmmm so from Windows Explorer I can RMB and get the Iproperties,Ilogic and run it from there without being in Inventor?
I literally will do an entire project from my Windows Explorer ... 50 drawings on average ..with a 1 time populate ...
Gotcha ...
I'm going to play with this weekend
Thanks for the info
Mike
