Inventor General Discussion
Active Contributor
Joe_Banger
Message 1 of 3 (159 Views)
Projecting surfaces to other surfaces
159 Views, 2 Replies
02-09-2014 09:10 PM
Hi My draftsman in his wisdom gave me a mid plane surface model for analysis. It was made in ACAD, and I imported it as a 3D sketch to patch into surfaces. However, the surfaces do not intersect (there are 1/2 " gaps through the surfaces), I need each surface to terminate onto its mating surface. I wish to quickly project them into their mating surface, not make millions of 2D sketches and patch then stitch them. Is this possible?
sam_m
Message 2 of 3 (142 Views)
Re: Projecting surfaces to other surfaces
02-10-2014 01:03 AM in reply to: Joe_Banger
without an image or a file I'm not 100% sure what you're after.  But, if you just need the existing surfaces to "grow" a little to let them intersect then you could try the "extend" command (tucked away in the Surface drop-down) or the Patch command to fill any voids?
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Active Contributor
Joe_Banger
Message 3 of 3 (120 Views)
02-10-2014 01:13 PM in reply to: sam_m
YES, this is it! Thank you, yes my example was quite insufficient, English is my 2nd language and I struggle to make myself clear without tuition. The thing that 'got' me was the fact that extend was hidden and in a drop down command menu.
