Inventor Forum
Projected Section view not alligned in IDW
3 REPLIES 3
John_Col
721 Views, 3 Replies
It seems that there is a problem with the section view function in Inventor.
The projected section view is not ailgned with the base view.
I assume that the attached screenshot is very clear.
Is there any patch who corrects the problem?
I have found a similar problem to mine here :
http://forums.autodesk.com/t5/Autodesk-Inventor/Section-view-not-parallel-with-Section-line/m-p/3234...
3 REPLIES 3
Paul-Mason
in reply to: John_Col
The part may not be constrained properly in you ipt file. Check your constraint's as well Horizontal and vertical alignment to the work plain
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
SBix26
With the jog in your section line, how could it be aligned?  The length of the section is greater than the width of the part, so they will not line up.  How would Inventor know what edge needs to be aligned?
John_Col
in reply to: SBix26
A colleague confirmed me the solution.
So, in fact this behaviour is tottaly normal.
The drawing rule is that when a section is drawn in this way, the result is deployed. So the borders are not aligned.
Sorry if it's not very clear.... My english have some limitations 😄
Anyway, problem solved for me.
Many thanks for the answers.
