After working as expected my recent attempts at geometry projection result in a black (rather than purlpe) projected line with a FIX constraint. This black/FIX projected geometry does not move with the parent geometry. Geometry previously projected is purple, has no FIX constraint and moves with parent geometry.
The only settings changes I remember making are on the Assembly panel under "In Place Features". I had to turn "Adapt Feature" off as Frame Generator would not mitre sections with this setting on. I now leave this setting on and turn it off when using Frame Generator.
Thanks in advance
Autodesk Product Design Suite Premium 2013 Inventor SP1.1
HP Z600 Workstation
Intel Xeon CPU E5620@2.40GHz
8GB RAM 64-bit
