Hello!
I'm a really fresh user when it comes to using Autodesk Inventor and I need some help with producing an element to a drawing.
I have a simple pipe with flanges in which I've made a arbitrary hole in the side using a projected area (located outside the structure). Due to the curvature of the pipe, this hole is larger than the area I have projected. What I want to do is illustrate an area that can be used as a template which is attached to the pipe to and cut accordingly. I have drawn the pipe by revolving it around an axis.
So, is there a way to take this area that I have cut out from the pipe, and fold it out flat on a drawing to get the correct size?
I hope I am clear enough in my description, please ask for clarification if needed.
/Regards, Thyman
Solved by LT.Rusty. Go to Solution.
Yes.
Derive Component as surface body.
Thicken and Rip.
Flat Pattern in Sheet Metal environment.
Attach your file here if you can't figure it out.
Hello JDMather!
Thanks for a rapid reply! Altough I'm afraid I can't quite follow how to proceed. As mentioned, my experience with Inventor is very limited at the moment.
I tried to open a new project as sheet metal, I derived the complete stucture as work surface, I then thicken the rim surrounding the hole, but I can't seem to rip it properly. Am I on the right track?
I have attached my original file as suggested. Sorry for the inconvenience.
Regards
Extract and Open the Flat Pattern part in this folder.
Click on Flat Pattern.
I did this as a template to wrap around your pipe.
If you actually intended to do the pipe as flat, then I would need to change the Thicken.
Here, take a look at these files.
I did it a little differently - I used a split instead of a rip, and only made one half of the template, but the basic principles are the same.
Rusty
