I can bring part in to a drawing file. I want to draw a sketch, projecting the lines and curves from the view. How to do it?
I can draw a sketch, but can't constrain to the current view.
Solved by scottmoyse. Go to Solution.
select the view before you click on the create sketch button. Or highlight and the right click on the view and then select new sketch. then you can project the edges of components from the view into the sketch
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
u dont have to wait for an answer if you look in the help files. 😉
Scott Moyse
