Inventor Forum
Project setup and libraries
1 REPLY 1
291 Views, 1 Reply
I have a folder under libarires in my project setup where I plan to keep my library parts. Once there the parts are read only. my questions is should I not have them there. I cannot modify then if i need to and if I copy it out to change it they do not update in the library.
What is the best way about setting up libraries in my project setup?
Tom
1 REPLY 1
Curtis_Waguespack
Hi tmulligan,
I discuss the use of Librarian projects to do this for read only Content Center parts at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/As-Custom-VS-As-Standard/m-p/3333323#M426023
You can use the same strategy for any libraries.
As an added note, if you're using Vault there is a school of thought that you needn't use libraries, since everything in the Vault is locked down.
I hope this helps.
Curtis
