Even as a single user, I would use the semi-isolated mode. That way
everything resides on the server and you check out files locally you are
working on. Another alternative might be upgrading and using Vault.
The semi-isolated environment is detailed in the file, "Autodesk
Inventor 6 File Management.doc", in the Documentation folder on your IV CD.
koehler wrote:
> I have set up all my project locations on my local c drive, being a
> single user, and at the end of the day would sent it to the server to be
> backed up. Recently my hard drive crashes and received a new computer.
> When I try to actvate a project it is not recognized therefore I must
> open my files from the server.
> What action should be taken so that all my projects which reside at
> C:\Inventor\... can be made current from the server?
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
