Inventor Forum
Project Geometry
5 REPLIES 5
pmh1718
547 Views, 5 Replies
Project Geometry
I used "project geometry" in an assembly to locate and place a hole from one part to another. How do I save the new hole back to the original solid?
P.Hines
5 REPLIES 5
jletcher
in reply to: pmh1718
You should have edit part in place start sketch on surface you want hole project geometry then add hole finish edit. you cannot take an assembly hole feature and put it to the part.
JDMather
in reply to: jletcher
@Anonymous wrote:
.... you cannot take an assembly hole feature and put it to the part.
Actually I think there is a tool on labs to do this, but as you stated the part should have been edited in the context of the assembly in the first place rather than adding an assembly level feature.
pmh1718
Thanks J, that works.
stevec781
You can create a hole at assembly level with the bolted connection tool and the hole will be sent back to the parts.
I think JDMather is referring to the Feature Migrator tool from Labs. I've been using it for a while now. Works well, but deleting the hole (example) at the part level leaves the sketch/points of the hole in the part. Functionally this creates no problem. It's just annoying.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
