Is it possible that project geometry lines directly appear as construction lines in a sketch?
Without manual change them into.
Solved by JoyceZhou. Go to Solution.
Select construction before you project.
Is there a default option somewhere for projected lines as construction?
Not sure if it appropriate for me to put my 2 cents worth in here - But I can't delete them once they are projected - that is projected cut lines. I can change them to construction but not delete them.
