You probably need to have Cross Part Association active. The option is in
Tools/AppOps/Assembly; Under the Cross Part Projection section there is a
check-box. It can either be checked or unchecked to have it on all the time
(checked) or only active with Ctrl (unchecked). Assuming it's unchecked, use
"Ctrl LMB" and the projected geometry should be associative.
~Larry
"jurgen_eco" wrote in message
news:f1969c4.-1@WebX.maYIadrTaRb...
> Hi,
> When I project some edges from one part to another part in an iam the
lines don't update when the "reference" part is changed. Do I miss something
here? Because it took me an hour to fix all the errors about missing
geometry. At the end Inventor trow me out AGAIN (jeeez that was not a
surpize). So now I can restart AGAIN. But I wan't to know the use of project
geometry in an assembly. Otherwise I sketch the part and do not use the
project stuff anymore in an iam. But hey, where's the productivity then?
> Adaptivity is no option anymore to me, I'm sick of that
cross-part-section-has-failed-error
> Kind regards.
