Inventor Forum
Project Geometry - BUG?
6 REPLIES 6
315 Views, 6 Replies
Part100 - base part.
Creating a new Assy, inserting Part100 and creating Sheet Metal Part101.
Contraining the 2 parts (edges) - Flush and Flush.
Work on Part101 and Project the cutout from Part100. Offset this cutout and
cut thru.
Now if I change Constraint Flush to 20 the Offset disapears (2 cutouts
are the same size) and if I change the other Flush to 5 the cutout changes
its shape. You can change the numbers and it still happens.
Attached - 3 JPG pictures to show the problem.
See INV files in CF.
Alon Gil
alon@chaban.co.il
6 REPLIES 6
This a known problem by Autodesk, lots of workarounds, one posted to iCF
under yours.
Laurence,
Power is nothing without Control
"Alon Gil" wrote in message
news:4BAC7FEF58B24C94CE83744518474111@in.WebX.maYIadrTaRb...
and
> cut thru.
> Alon Gil
> alon@chaban.co.il
Yes but for INV6. Was sure this will be fixed in INV7.
Alon
"Laurence Yeandle" wrote
in message news:9A069181B1F03C8F83B56D2FA169CC93@in.WebX.maYIadrTaRb...
> under yours.
> Laurence,
> and
> > cut thru.
changes
> > Alon Gil
> > alon@chaban.co.il
Alon I had your model working with a work around and I normally check it
before posting,.......but the model I posted falls apart! ( I am really
rusty )
Can someone delete my model in iCF..save me anymore embarrassment ta.
Yes as I remember it was going to be fixed.
Laurence,
news:F2E76B58E0864893168C1FFB8F69563D@in.WebX.maYIadrTaRb...
> Alon
I think you can delete it by youself.
Mark it, go to Message and choose cancel message.
Alon
in message news:E88279C9DE82C2E8CE44679B670627A8@in.WebX.maYIadrTaRb...
> rusty )
> Laurence,
> > Alon
It is Sunday.......I could of stayed in bed or even gone out on my bike but
no I just made a complete pratt of myself.............easy huh.
You learn something new here every thanks for the pointer.
Laurence,
news:D1F9EF174A966E0119B608C2FD7227A8@in.WebX.maYIadrTaRb...
> Alon
It is not currently possible to delete your own messages. I will go
remove Laurences post for him. 8^)
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
