Inventor Forum
project flat pattern
3 REPLIES 3
185 Views, 3 Replies
If you edit Sketch3 (Cut1) on this part, why can't you project either of the
flanges as a flat pattern?
3 REPLIES 3
Kevin,
The part somehow seems to be corrupted. Mirror1 is causing the flat pattern
to fail. I could not reproduce the problem from scratch. Did you remember
anything unusual when you first created? Could you try it on your machine
and see if you could reproduce it?
Thanks!
Johnson Shiue
Test Engineer
"Kevin Wehner (IV10)" wrote in
message news:4857977@discussion.autodesk.com...
I created a part, then saved copy as twice to make two similar parts. The
part I sent is one of the copies. The other copy does not work either, but
the original does. I tried making a third copy and got the same result. I'll
e-mail you the original file in the morning.
"Johnson Shiue [Autodesk]" wrote in message
news:4858135@discussion.autodesk.com...
Kevin,
Thanks!
Johnson Shiue
Test Engineer
I was wrong. The original file let me project the mirrored flange but not
Flange1.
"Kevin Wehner (IV10)" wrote in message
news:4858141@discussion.autodesk.com...
Kevin,
Thanks!
Johnson Shiue
Test Engineer
