I have an assembly of pallet racking, it is one complete frame which can be modified in all the desired ways by the ilogic i have in place. I wish to be able to put this frame into a new assembly but have different dimensions for each frame. I used to do this by copying all the files to a new folder so that each frame had its own parts. This has stopped working and now once one frame is altered all the other frames change to rather than having there own dimensions.
Thanks in advance
Solved by CCarreiras. Go to Solution.
Hi!
So you're using an iLogic Assembly to create several versions of a frame design, and put those different versions in another Asembly?
You can try this:
Tip: You have a option to export the copy without any iLogic rule.
Mantain the diferent versions in separate folders (or you have to rename all parts). Rename the iLogic copy for each version though.
For other versions, open again the iLogic assembly and do again all the steps behind.
Hope it works that way.
Regards.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
