Inventor General Discussion
Valued Contributor
dominiekvanwest
Message 1 of 6 (161 Views)
Project cut edges error
161 Views, 5 Replies
07-09-2012 07:03 AM
I found a weird thing with the command 'Project Cut Edges'. I'll explain what I did. I made a new part and added a derived part. This derived part consists of 2 beams (see top left picture in attachment) (these beams are NOT Content Center parts, but I drew the beams myself, so it would be the same if I drew just rectangles as beams). The beams are at a specified distance of each other (see top right picture in attachment). I added a sketch on the YZ Plane and clicked on 'Project Cut Edges' (see bottom left picture in attachment). I added a rectangle and extruded the rectangle. But if I click on the 'Project Cut Edges' item in the browser under Sketch (or I open the Sketch), not all the lines are there anymore. And if I make the distance between the beams smaller, the lines get shorter too (and vice versa).
What is wrong here?
Thanks in advance!
Dominiek
CAD-One
Message 2 of 6 (138 Views)
Re: Project cut edges error
07-10-2012 04:40 AM in reply to: dominiekvanwest
You are trying to cut material off of surfaces. Try this. Rmb derived part and click edit. I see currently you have surfaces mode. So, select solid instead.Hit ok. You extrude should work now.
C1
Inventor Professional 2015
Vault Professional 2015
Valued Contributor
dominiekvanwest
Message 3 of 6 (128 Views)
07-10-2012 05:12 AM in reply to: CAD-One
I do not want to cut anything, it's just an extrusion of a rectangle (I needed a feature to show the problem).
The problem stays the same when I change surface to solid.
*Pro
jletcher
Message 4 of 6 (124 Views)
07-10-2012 05:45 AM in reply to: dominiekvanwest
This has been an issue for a very long time sometimes it works other times it don't most don't.. I stay away from it I just project the edges and stay away from project cut edge. I know this don't help. But just maybe just maybe in release 2050 it will be fixed.....................
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor
dominiekvanwest
Message 5 of 6 (118 Views)
07-10-2012 06:00 AM in reply to: jletcher
Thanks for the reply!
In the meantime I already did what you suggest, just project the edges myself (with project geometry) instead of using project cut edges. It works for now, but of course I would like the project cut edges to work correctly.
*Pro
jletcher
Message 6 of 6 (113 Views)
07-10-2012 06:11 AM in reply to: dominiekvanwest
Yes I agree it should work. But to let you know when it did work I found issues with performance...
James Letcher
