Hi, I am a programmer and im trying to use the 'Measure.ExtentsLength', 'Measure.ExtentsHeight' & 'Measure.ExtentsWidth' found in the snippets which inventors ilogic offers.
a (correct/working) rule that i currently have working in a part document is:
Dim Length As Integer = 0 Dim Height As Integer = 0 Dim Width As Integer = 0 Length = Measure.ExtentsLength Height = Measure.ExtentsHeight Width = Measure.ExtentsWidth
however when i am programming in vb.net/c++ my code is:
Dim InvApp As Inventor.Application Dim PartDoc As InvApp.PartDocument = "filepath of part" MsgBox(PartDoc.Measure.ExtentsLength) '<---------error
what are the librarys/headers that I have to declare find the Measure.ExtentsLength?
Thanks in advance, Craig
What are you trying to do there is very little on ilogic be better if you tell use what you are trying to do.
My program will create a drawing from any part. Below is the complete - working ilogic rule, that i am trying to translate over to my stand-alone program.
Imports Inventor.ViewOrientationTypeEnum Imports Inventor.DrawingViewStyleEnum ' UPDATE PROPERTIES' iLogicVb.RunRule("Update Properties") 'END UPDATE PROPERTIES' Dim oDrawDoc as DrawingDocument Dim oPartDoc as Document Dim oSheet As sheet Dim oTG As TransientGeometry Dim oBaseView As DrawingView Dim oView2 as DrawingView Dim oView3 as DrawingView Dim oView4 as DrawingView iLogicVb.RunRule("CalcMaxValues") Dim DScaleSize = 150 Dim ViewScale = DScaleSize / MaxMax Dim Scale20 = (ViewScale/100)*20 Dim IsoScale = ViewScale-Scale20 oPartDoc = ThisDoc.Document 'Define IDW Template File Location oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "R:\Drawing Library\INVENTOR\Templates\Craig Templates\IDW PART.idw", True) oSheet = oDrawDoc.Sheets.Item(1) 'Define 2d view bottom left corner points for four views - sets the location to place the views (x,y) coordinates oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(10, 14) oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(10, 30) oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(35, 14) oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(50, 32) oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default") oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, ViewScale) oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, ViewScale) oView4 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint4, kHiddenLineDrawingViewStyle, IsoScale) 'get the path and file name of the selected item Dim CurFileName = ThisDoc.ModelDocument.FullFileName 'find the postion Of the last backslash In the path Dim FNamePos = InStrRev(CurFileName, "\", -1) 'get the file name with the file extension Dim Name = Right(CurFileName, Len(CurFileName) - FNamePos) 'get the file name (without extension) Dim ShortName = Left(Name, Len(Name) - 4) 'get the path of the folder containing the file Dim Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name)) Dim strFolder As String = Folder_Location & iProperties.Value("Summary", "Title") 'ThisDoc.Document.SaveAs(strFolder & (".dwg") , True) '**************************** oDrawDoc.SaveAs(strFolder & ".idw" , False) oDrawDoc.Close(False) DrawingDoc = ThisApplication.Documents.Open(strFolder & ".idw" , True)
the problem i am having is that because my program is seperate, it can't find where the Measure.ExtentsLEngth is stored. eg/ Inventor.MeasureTools.Measure.ExtentsLength
I need to know where the function for measuring the extents are.
Hi craigzcool,
This thread might help:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Extents-of-parts/m-p/1869988
Keep in mind you'll likely find better search results on the customization forum for programming questions:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Well Curtis is alot better at this then I am so I will let him lead you from here.
