Well with the skeleton file and updating all the parts I now crash every time trying to
open the IAM. All the parts seem to open and update fine so my guess is the IAM is
somehow corrupt. Do you have a copy in the OldVersions dir that works?
I am still not sure what the Assembly level features are for, but didn't really look into
them (when I could open the IAM.
T-Base Gusset - Bottom.ipt Shows that it needs to be updated if the skeleton is missing,
but if the skeleton is there it doesn't?? Also if I rename the skeleton and try to open
the iam it is the only one that is defaulting to this
path...K:\Standards\T-BASE\INVENTOR\SKELETON.ipt I suppose that is because it hasn't had
its path reset yet since it doesn't update??
Not sure if it matters or not, but when I do a master sketch assembly I only bring in what
is needed to each part. You appear to be brining in everything from the master to each
one. Seems overkill?
Sorry not much help, hopefully the one in the OldVersions folder works.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Mike Drabic" wrote in message
news:f163ab2.6@WebX.maYIadrTaRb...
> sorry about that. I posted that file.
> please help
> mike
