I use a tool which clears Autodesk references from the profile & this fixes a variety of issues.
Generally if the problem isn't seen when logging on as a different user then the profile is to blame.
Can someone explain what the profile does & why it needs to be 'cleaned up' so frequently? Some machines appear to be effected more than others - looking for reasons why this is happening.
Cheers
MES
Mark, I can't offer any advice on what the profile does or how it does it. But I have the same trouble as you on 1 machien and 1 user profile. IT set up a script to clear out the Autodesk stuff at each login of that user. It has fixed most of the issues but some linger.
IT have completely formatted the HDD and re-installed OS and apps and when the problematic profile is used it creates issues in Inventor and Vault. I had a temporary new profile made for the user and it worked for a few months. But then the errors started creeping in.
I would be very interested in learning about the 'tool' you refer too.
hello
The tool is here
copy & paste into notepad & save as .bat file
MES
