Hello everyone,
I have a slight issue with a profile I am drawing!
On the top surface It needs a ellipse curve, but on the end of the chair has a profile/detail already on..
Basically as per picture attached, what are my options?!
Regards
tried a loft? Probably will have to do as a surface and then sculpt it into a solid after.
use the existing side edges as rails and possibly add a new rail along the centre showing how you want the middle of the bottom face blending into the middle of the top face.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
