I've got a step file from a supplier, but i can't convert it into a solid 3D model.
I'am getting a lot of error messages in Inventor 2012 when i'am doing an import.
Does someone succeed with the attachment?
I'am very curious how you did it.
Thanks.
Jan
Quickly, I was able to get it to open, but there is some work that will need to be done in the construction environment. Sorry, ran out of time...
This was done in 2010...
There are a lot of surfaces missing.
Do you really need as a solid - or will a composite surface body be good enough?
