Have you gone through this document http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
When you do a pattern cut Inventor tries to cut the same volume as was cut in the seed to save calculation speed. If a different volume must be cut you must tell Inventor to Adjust to the geometry.
