whi guys
sorry for my bad english
but iam working on frame for a bus iam making one side painel estrutural and i have problem making frame with frame generator .. is possible make a cut in start and end of frame with degrees like 45º?? . i try made a trim with a plane but is impossible ... any expert can help me pls ... one easy way??
thks
pedro ferreira
Welcome to the forums!
It is hard to tell from your picture, but is that piece protruding form the end of the frame? If is it, you may have to use a Cut Extrusion with a sketch to get that 45% miter. If this is an actual corner in the frame itself, there is a miter tool in Frame generator you can use.
Does that make sense?
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
i dont now how to do Cut Extrusion with a sketch to get that 45% ....
iam stuck with cut corners :(:(:( ani tutorial to explain ???? ... iam gona attack another problem cut frame ...
thks for the help 🙂 ani tutorial ??
Wow,
From that picture it is very hard to figure out what you want to do. Can you post your assembly here?
How much training have you had in Inventor and Frame Generator?
Chris Benner
iam gona explain
i work in company how build bus, i work with autocad all this time ... and now they give me to choice some other program , and i download the trial version of inventor and some others programs ... and so far i loved inventor ..
sorry for my bad english and my training so far is youtube .. i now wen the company i work buy inventor iam gona get training .. but iam making same tests to see how its work..
so far is good .i used only on sketch 3d and same planes to help. i now i need help and some orientacion. iam gona attack the work iam doing now is bus duble decker autocad view, 3d render view and my try in inventor
thks
pedro
Pedro,
If you do end up getting Inventor to work with, feel free to ask questions here anytime. It is a good design tool, and Frame Generator should be able to save you a lot of time, once you get used to working with it. Get some training if you can on the basics, and then practice, practice, practice.
Good luck!
Chris Benner
