This has happened since installing SP2.
I have a view on a drawing, on some of the vertical lines, with the general
dimension button pressed I no longer get the glyph with the left and right
arrows when hovering over a line (the lines only go red). It's not all of
the lines but the ones that I want to put a horizontal dimension between!
As a work-around I'm having to pick endpoints and then specify that it's a
horizontal dimension.
Anyone else seen this?
Cheers,
--Rob Singlehurst
