Inventor Forum
Problems shelling a simple tube design
19 REPLIES 19
Message 1 of 20
257 Views, 19 Replies
Someone please help.
Can someone explain why I'm getting an error shelling a simple tube? The
part shells fine with one or two branches, but when I change the rectangular
pattern to 3 occurances, I get an error.
This question will probably make much more sense when you look at the file
under ICF.
Thanks for any help.
19 REPLIES 19
Message 2 of 20
Don't believe your post made it to ivCF, Greg.
"Greg_L" wrote in message
news:963C14E2E635284543025A7584CF9938@in.WebX.maYIadrTaRb...
> under ICF.
Message 3 of 20
Jeff,
It's there, but I think it's an R8 file.
darvin
"Jeff Howard" wrote in message
news:AB3DD334B5D16A8B80CF4F6BBB03EE8B@in.WebX.maYIadrTaRb...
The
rectangular
the file
> > under ICF.
Message 4 of 20
It may be in your cache, but it was removed a while back. 8^)
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"darvinv" wrote in message
news:23A2DE8A7E9CF3848A584D6CACC283DF@in.WebX.maYIadrTaRb...
> Jeff,
> darvin
Message 5 of 20
Kinda what I figured. KWik Moderation.
darvin
"Kent Keller" wrote in message
news:44BFB724961EF5E75394818F15623F56@in.WebX.maYIadrTaRb...
> Kent Keller
> Assistant Moderator
> > Jeff,
> > darvin
Message 6 of 20
Ahhh. Just as well. Too late for me to be delving into something anyway.
8~)
news:C6547DFD789F72E1D5109DA1860D2CC7@in.WebX.maYIadrTaRb...
> darvin
Message 7 of 20
Oops. I goofed.
Sorry about the "version" problem ;). Won't happen again. I posted the new
file just a few minutes ago under ICF.
Thanks for the help.
news:72F6F337FB0F28682A73C75229746EF4@in.WebX.maYIadrTaRb...
> 8~)
> > darvin
Message 8 of 20
The part with three branches shells fine in the latest R8 build.
Loren Jahraus
Autodesk Inventor Workflow Team
news:0922C4A100D209879979CEFA6829E978@in.WebX.maYIadrTaRb...
> Oops. I goofed.
new
anyway.
> > 8~)
> > > darvin
Message 9 of 20
That's good. 8~)
Greg, it's just a bug. If you need the part, derive the solid body and shell
the derived part.
"Loren Jahraus (Autodesk)" wrote in message
news:1296C7E78065928C63A93322E85EBF21@in.WebX.maYIadrTaRb...
> Loren Jahraus
Message 10 of 20
Loren,
Actually, I tried the shell using build 057d and still got the error. I
have no problem shelling the entire part (removing only the end faces of the
three small tubes), shelling the entire part (removing no faces), shelling
the entire part (removing the end faces of the three small tubes and the
front and back faces of the big tube), but I can't shell and remove the
three small tubes and only ONE face of the big tube. I have the same
problem with either version. Let me know if you have the same result.
Greg Lock
Ceric, Inc.
> Loren Jahraus
> > Oops. I goofed.
> new
> anyway.
> > > 8~)
> > > > darvin
Message 11 of 20
grag,
Put a little (2.5 mm works) on the sweep, move it up and add it to
the pattern. Then the shell solves.
darvin
news:46551BB18F027B21979ED4EADF1A0BE7@in.WebX.maYIadrTaRb...
> Loren,
I
of the
shelling
the
the
> Thanks
> Greg Lock
> Ceric, Inc.
message
> > Loren Jahraus
> > > Oops. I goofed.
posted the
> > new
message
something
> > anyway.
> > > > 8~)
> > > > > darvin
Message 12 of 20
Darvin,
I'm not exactly sure what you mean. Is it possible to put your example in
ICF?
Greg
news:4A87D1C104CAC31D64A5EA6D15A1F628@in.WebX.maYIadrTaRb...
> grag,
> darvin
> > Loren,
> I
> of the
> shelling
> the
> the
> > Thanks
> > Greg Lock
> > Ceric, Inc.
> message
> > > Loren Jahraus
> > > > Oops. I goofed.
> posted the
> > > new
> message
> something
> > > anyway.
> > > > > 8~)
> > > > > > darvin
Message 13 of 20
Sorry, already burned it. Just put a small fillet (2.5 mm) at the
junction of the sweep and the extrusion. Then drag it up above right
below the sweep. Edit the pattern and add the fillet. Watch the shell
solve.
darvin
news:6263E4FA7A9F2C3692EE984FD6249614@in.WebX.maYIadrTaRb...
> Darvin,
example in
> ICF?
> Thanks,
> Greg
> > grag,
to
> > darvin
> > > Loren,
error.
> > I
faces
> > of the
> > shelling
and
> > the
remove
> > the
same
result.
> > > Thanks
> > > Greg Lock
> > > Ceric, Inc.
> > message
> > > > Loren Jahraus
> > > > > Oops. I goofed.
> > posted the
> > > > new
> > message
> > something
> > > > anyway.
> > > > > > 8~)
> > > > > > > darvin
Message 14 of 20
greg,
Check iCF for two solutions, under your thread. #2 (-dd2) is better,
as it retains your sharp intersections.
darvin
> Darvin,
example in
> ICF?
> Thanks,
> Greg
> > grag,
to
> > darvin
Message 15 of 20
Good find, Darvin. Did you try it after filleting each pattern instance
seperately? 8~)
Greg, sorry to waste your time. I wasn't paying attention and excluded all 5
planar faces when I tried it (works with the original part, too).
news:FAE23A7C238823727359B267BFA3D6B1@in.WebX.maYIadrTaRb...
> solve.
> darvin
Message 16 of 20
Jeff,
Nope, ran out of steam and decided that using an extrusion cut on
the collector tube, followed by sweep cuts on the intakes, was a better
way to go. No need to mess up the original intent and kill the sharp
corners that way.
But I did notice, when applying the fillet, that the pattern
features previewed differently from the original sweep. Gut said, fillet
the original and add to the pattern. Sometimes that sinking feeling is
reliable.
darvin
news:DA61AF8CCAD8A0F653F75E7E1FFF6171@in.WebX.maYIadrTaRb...
instance
> seperately? 8~)
excluded all 5
shell
> > solve.
> > darvin
Message 17 of 20
Well, just beat it into a shell of it's former self. Of the 3 fillet
schemes, using2.5mm, only including it in the pattern allows the shell
to solve.
darvin
instance
> seperately? 8~)
excluded all 5
shell
> > solve.
> > darvin
Message 18 of 20
I opened the part with the failed shell, did a Rebuild All, and the shell
worked. The ASM team has made some improvements to the kernel since the beta
build was released.
Loren Jahraus
> Loren,
the
> Thanks
> Greg Lock
> Ceric, Inc.
> > Loren Jahraus
> > > Oops. I goofed.
the
> > new
> > anyway.
> > > > 8~)
> > > > > darvin
Message 19 of 20
8~) Go figure...
Oh, well. It'll all be different in a few weeks.
Have a great one.
news:2AB294051FADBBACC862EED39176D18A@in.WebX.maYIadrTaRb...
> to solve.
> darvin
Message 20 of 20
Darvin,
Fogive me for being a mindless idiot. It took me at least 20 minutes of
reading the last few messages between you and Jeff and looking at your files
under ICF before I understood what you meant by a small fillet. Now I
understand and your work around is just what we were looking for.
Thanks again.
Greg
news:26DB3B21B0373903EAF26C538226A170@in.WebX.maYIadrTaRb...
> greg,
> darvin
> > Darvin,
> example in
> > ICF?
> > Thanks,
> > Greg
> > > grag,
> to
> > > darvin
