Sorry, already burned it. Just put a small fillet (2.5 mm) at the
junction of the sweep and the extrusion. Then drag it up above right
below the sweep. Edit the pattern and add the fillet. Watch the shell
solve.
darvin
"Greg_L" wrote in message
news:6263E4FA7A9F2C3692EE984FD6249614@in.WebX.maYIadrTaRb...
> Darvin,
> I'm not exactly sure what you mean. Is it possible to put your
example in
> ICF?
> Thanks,
> Greg
> "darvinv" wrote in message
> news:4A87D1C104CAC31D64A5EA6D15A1F628@in.WebX.maYIadrTaRb...
> > grag,
> > Put a little (2.5 mm works) on the sweep, move it up and add it
to
> > the pattern. Then the shell solves.
> > darvin
> > news:46551BB18F027B21979ED4EADF1A0BE7@in.WebX.maYIadrTaRb...
> > > Loren,
> > > Actually, I tried the shell using build 057d and still got the
error.
> > I
> > > have no problem shelling the entire part (removing only the end
faces
> > of the
> > > three small tubes), shelling the entire part (removing no faces),
> > shelling
> > > the entire part (removing the end faces of the three small tubes
and
> > the
> > > front and back faces of the big tube), but I can't shell and
remove
> > the
> > > three small tubes and only ONE face of the big tube. I have the
same
> > > problem with either version. Let me know if you have the same
result.
> > > Thanks
> > > Greg Lock
> > > Ceric, Inc.
> > > "Loren Jahraus (Autodesk)" wrote in
> > message
> > > news:1296C7E78065928C63A93322E85EBF21@in.WebX.maYIadrTaRb...
> > > > The part with three branches shells fine in the latest R8 build.
> > > > Loren Jahraus
> > > > Autodesk Inventor Workflow Team
> > > > news:0922C4A100D209879979CEFA6829E978@in.WebX.maYIadrTaRb...
> > > > > Oops. I goofed.
> > > > > Sorry about the "version" problem ;). Won't happen again. I
> > posted the
> > > > new
> > > > > file just a few minutes ago under ICF.
> > > > > Thanks for the help.
> > > > > "Jeff Howard" wrote in
> > message
> > > > > news:72F6F337FB0F28682A73C75229746EF4@in.WebX.maYIadrTaRb...
> > > > > > Ahhh. Just as well. Too late for me to be delving into
> > something
> > > > anyway.
> > > > > > 8~)
> > > > > > news:C6547DFD789F72E1D5109DA1860D2CC7@in.WebX.maYIadrTaRb...
> > > > > > > Kinda what I figured. KWik Moderation.
> > > > > > > darvin
