Inventor General Discussion
Active Member
austinhall
Message 1 of 5 (898 Views)
Problems importing/opening DWG files from AutoCAD 2014 to Inventor Pro 2014
898 Views, 4 Replies
03-16-2014 01:04 AM
I'm having trouble importing or opening Autocad 2014 .dwg files into Inventor. I'm running Inventor Pro student edition on Windows 8 running on Parallels on a Mac. Autocad 2014 is running on Mac.
I have tried the techniques described in the essentials skills video.
When i select a file to import i cannot see a preview, which is one point of difference to the essential skills video and other youtube tutorials. I'm selcting a file both from a windows 8 folder and from the Mac folder each shows no preview and each has no further option and nothing happens when i select 'open'.
I can open an AutoCAD file in the viewer (a simple square) however i cannot copy anything into the model space, i cannot paste anything onto a plane where i have inserted a 2D sketch.
Also the DWG/DXF wizard does not show up when i try to import a file as in the online videos, no options of selecting line types and what to import etc.
I'm importing very specific aero foil shapes which have been generated on aeronautical design programs and exported/imported to Autocad so i cannot simply redraw them in Inventor, could there be a problem with that file? I cannot even import a square or circle so it can't be just the file type.
I'm at a losss to explain this, i have no idea what to do now and i'm very frustrated. I have spent about 6 hours following every tutorial and video instruction explicitely.
I've attached a wing foil section file for others to try. Is there a formating issue or a missing step or restriction with the student version?
Any help or suggestions would be very much appreciated.
Austin
JDMather
Message 2 of 5 (880 Views)
Re: Problems importing/opening DWG files from AutoCAD 2014 to Inventor Pro 2014
03-16-2014 03:44 AM in reply to: austinhall
The student license is fully functional.  I just imported your dwg into Inventor Pro 2014 Student License.
Have you installed Service Pack 1 and Update 3 for Service Pack 1?
Many threads here on running Inventor in Win 8(.1) having trouble with importing AutoCAD - have you tried the solutions in those discussion threads?
What is the website that you are getting that profile (does it output Excel or txt file?  Inventor can create also create a profile from Excel or txt.   Or you can use an equation curve.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
austinhall
Message 3 of 5 (874 Views)
03-16-2014 03:51 AM in reply to: JDMather
Thank you very much for your reply, i will follow up with you reccomendations. I have not updated the service pack yet, i have searched for other AutoCAD import problem threads but couldn't find many i will have a further look and try any solutions outlined and try to import again. Thank you for your help.
Active Member
austinhall
Message 4 of 5 (871 Views)
03-16-2014 03:59 AM in reply to: JDMather
The foil curve is from a software called profili2. http://www.profili2.com/eng/default.asp
There is software available that will export numerical data for common foils in a .txt file but profili has greater development and tools.
Thanks, i'll follow up the other AutoCAD import threads.
JDMather
Message 5 of 5 (864 Views)
03-16-2014 04:36 AM in reply to: austinhall
austinhall wrote:
...i have searched for other AutoCAD import problem threads but couldn't find many i will have a further look and try any solutions outlined and try to import again. Thank you for your help.
http://forums.autodesk.com/t5/Inventor-General/When-inserting-importing-DWG-files-into-Inventor-noth...
