Inventor General Discussion
Valued Contributor
SORJM
Message 1 of 7 (486 Views)
Problems after installation of Service Pack 1 of Autodesk Inventor 2012
486 Views, 6 Replies
03-02-2012 07:14 AM
After installing the Service Pack 1 of Autodesk Inventor 2012, shortcut keys like M (Measure Tool), Ctrl+0 (Clean Screen) has stopped working. Dimensions are not placed automatically during line, arc,etc creation.
Please help me in solving this problem?
Thanks in advance.
Nisheeth Srivastava
Inventor 3-D Parametric Solid Model Drawing (Video Tutorials)
My CAD Creations
Distinguished Mentor
john.retzlaff
Message 2 of 7 (478 Views)
Re: Problems after installation of Service Pack 1 of Autodesk Inventor 2012
03-02-2012 08:06 AM in reply to: SORJM
Try right clicking gray area of ribbon, customize user commands, Keyboard tab, button Reset All Keys.
For dimensions, check Application Options, Sketch tab, check your settings under Heads Up Display.
John Retzlaff
Valued Contributor
SORJM
Message 3 of 7 (463 Views)
03-02-2012 01:51 PM in reply to: john.retzlaff
John Retzlaff
After applying your suggestion Ctrl+0, Ctrl+S started working but M (Measure Tool), L (Line tool ) F7 ( slice graphic) shortcuts are still not working. Dynamic Input is appearing in the window, but to understand the my problem watch the video below
Dynamic Input
Regards
Nisheeth Srivastava
My CAD Creations
Valued Mentor
coreyparks
Message 4 of 7 (454 Views)
03-02-2012 02:27 PM in reply to: SORJM
Go into the Inventor application options and turn on the settings you see in the attached picture.  When you try the shortcuts it will show what ones are available when you type.  My guess is there are now more shortcuts that start with the same letter as the ones you are using.  If there are multiple that start with L in order to fire off the line command you will need to remove all others that start with L in that environment or hit the enter or spacebar after typing L to fire off the cammand.  Hope this helps.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
IV2014 Factory Design Suite Ultimate
Windows 7 64 bit
Synergis Adept document management software
16gb RAM --- Nvidia Quadro 4000 2gb
Valued Contributor
SORJM
Message 5 of 7 (319 Views)
05-23-2012 01:41 AM in reply to: SORJM
Hello John Retzlaff,
I have reacently facing a new problem with ribon tab. While working on drawing file on ribbon pannel Annotate tab is not visible. Instead of this Annotate (ESKD) is visible. I tried reset ribbon but the problem is still the same. See the screen shot below.
How can I solve this problem?
Regards
Nisheeth Srivastava
My CAD Creations
john.retzlaff
Message 6 of 7 (302 Views)
05-23-2012 05:12 AM in reply to: SORJM
Go to Tools, Add-Ins and unload ESKD Support.
John Retzlaff
Valued Contributor
SORJM
Message 7 of 7 (280 Views)
05-23-2012 05:00 PM in reply to: john.retzlaff
Thanks a lot  john.retzlaff. After applying the settings mentioned by you my problem solved.
Regards
Nisheeth Srivastava
My CAD Creations
