Inventor Forum
Problem with Using Drawing feature
3 REPLIES 3
k-m2011
271 Views, 3 Replies
I'm in grade 12 and i had to create a vending machine and i did. But the problem is when i use the drawing feature in inventor it isnt showing the whole vending machine only parts of it...
look:
how do i get the whole machine to show??
3 REPLIES 3
JDMather
in reply to: k-m2011
Show screen shot of the part or assembly ipt/iam or attach the files here.
k-m2011
in reply to: JDMather
okay i have attached it. thanks
rhasell
Hi
I have not analysed everything, but to fix your immediate issue.
Expand the tree, find the solid body listed under "Surface Bodies", RMB and enable visibilty.
The reason this happened was the "Delete Face" feature. This converted the solid body into a surface Body.
Try use the Shell feature instead.
Reg
2024.2
Please Accept as a solution / Kudos
