I have an official Inventor 2015 on my PC. Problem is that icon "Thread" is simply doesn't work.
I choose a cylindrical surface in 3D detail on wich I want to make a thread and then push the icon "Thread" but nothings occurs.
Maybe there somebody had to have a problem like this?
Solved by admaiora. Go to Solution.
try this option, the Flip direction
Is it getting better?
Admaiora
Do you have MS Excel installed on this machine?
Did you run Excel at least once before installing Inventor?
Did you install Inventor with anti-virus and UAC disabled during install?
Is this a new problem, did it used to work. Or has it never worked?
Are you running dual monitors?
This can solve your case.
Admaiora
