Inventor General Discussion
New Member
0 Kudos
Post 1 of 4
Problem with inventor and JT
235 Views, 3 Replies
05-20-2013 01:08 PM
Hi
I have a JT file which I've opened in the latest trial of Inventor. I'm trying to export any STP, DWG, IGS of the contents of the JT (which display perfectly within Inventor) but nothing is ever exported. The resulting files seem blank. I've tried importing them into both Maya (dwg) and Rhino (stp, iges, dwg). Do I need to do anything in Inventor to get the meshes exported?
Employee
24 Kudos
Post 2 of 4
Re: Problem with inventor and JT
05-21-2013 04:03 AM in reply to: dmitrimang
Hi Dmitri,
Sorry to hear that you're having trouble. What version of Inventor are you using? Are you able to post the file with which you're working? If not, feel free to email me the part: inderjeet [dot] wilkhu [at] autodesk [dot] com
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk ShapeManager
Design, Lifecycle and Simulation
1,281 Kudos
Post 3 of 4
05-21-2013 04:43 AM in reply to: dmitrimang
Have you tried looking at any of the option settings before exporting the file?  Seeing if there are settings that might give you different results?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Employee
21 Kudos
Post 4 of 4
06-06-2013 11:04 PM in reply to: dmitrimang
Hi dmitrimang,
Thanks for reporting here !
I suppose your JT file has only mesh data, and it cannot be exported to STEP, IGES format, so you will see no data exported.
I don't have the perfect workaround for you now instead of some suggestion, you can contact the JT file provider to provide the JT file which has Brep data, then open it in inventor and export to STEP or IGES, it should work.
If this JT file is not very complex, you can use Inventor addin mesh enabler to convert mesh to Brep (solid or composite), then export it to STEP or IGES. You can download Mesh Enabler tool from  http://labs.autodesk.com/utilities/inventor_mesh and have a try, it is free.
Kevin Li
Quality Assurance Team
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
